Armstrong Arduino Uploading Code
After setting everything up, we can move on to uploading code to your Armstrong.
Choose what to upload
Next, in Arduino go to Tools -> Port, and select the port your Armstrong is connected to. It’s usually the only option available.
And that's it! You have now uploaded your code to the Armstrong. Great job!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 |
#include <Armstrong.h> void setup(){ Armstrong.begin(); } void loop(){ for(uint8_t i = 0; i <= 4; i++){ LED.set((Slot)i, true); } delay(500); for(uint8_t i = 0; i <= 4; i++){ LED.set((Slot)i, false); } delay(500); } |
Let's make sure your Armstrong is ready for the upload!
Turn on your Armstrong and plug it into your computer with a USB cable.
