Chatter 2.0 Arduino Uploading Code
After setting everything up, we can move on to uploading code to your Chatter 2.0.
Choose what to upload
Next, in Arduino go to Tools -> Port, and select the port your Chatter 2.0 is connected to. It’s usually the only option available.
And that's it! You have now uploaded your code to the Chatter 2.0. Great job!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 |
#include <Chatter2.h> Display* display; Sprite* sprite; void setup() { Chatter.begin(); display = Chatter.getDisplay(); sprite = display->getBaseSprite(); sprite->clear(TFT_BLACK); sprite->setTextColor(TFT_WHITE); sprite->setTextFont(2); sprite->setCursor(0,0); sprite->print("Hello World!"); display->commit(); } void loop() { LoopManager::loop(); } |
Let's make sure your Chatter 2.0 is ready for the upload!
Turn on your Chatter 2.0 and plug it into your computer with a USB cable.
