Using external bitmaps and editing firmware
When creating a more complex app, it's usually better to haveĀ bitmaps in a separate folderĀ and just to load them whenever you need them.
That way you can fix your images on the go and don't have to waste a lot of time converting them to code back and forth.
A good example of that one is ourĀ Space RocksĀ game for Ringo. You can check its repositoryĀ here.
Space Rocks repository on GitHub
You'll notice that besides the main files, Space Rocks has bothĀ SoundsĀ andĀ SpritesĀ folders.Ā
Both of those folders have files that are being used in-game.Ā
Here is how theĀ SpritesĀ folder looks on the inside.
Sprites folder from the Space Rocks repository
You'll notice someĀ bitmapsĀ andĀ .cĀ files. That way you can use both functions that we've learned in the previous lesson.Ā
Checking out theĀ SpaceRocks.inoĀ file will help you understand this whole process much better, so make sure to check it out in detail if you wish to learn more.
First few lines of the SpaceRocks.ino file
Editing firmware (advanced)
If you're feeling reaaaally good and want to change some of the things in our original phone firmware, you can do so!
We always encourage new creations and personalizations, as long as you share them on ourĀ forumĀ so that everyone else can use them too. :)
If you're unfamiliar with the process ofĀ building the firmware form source files, our most active forum members along with our staff have created aĀ cool topicĀ where you can find all the details, and fixes to potential problems, on how to download, build and upload your own version of Ringo firmware.
If you have any experience in doing these things, it will not take you more thanĀ 15 minutes to set everything up.Ā
However, if you've never encountered these things, you might have some more issues. We still encourage you to do so since you'll learn so much in the process.
Once you've done so, the file on which you'll be focusing the most isĀ sprites.c.
We've already shown you how the file looks and how things work, so there's no doubt that you get the grip of things and personalize your phone in a matter of minutes!
If you get stuck, you can always hit us up on our community forum,
Ā where the whole community and our staff are eager to help you and explore further parts of this project.
Now - start making!
