Electronics 101
1. Circuit board
The yellow bee-shaped thingy you've gotten in your kit is called a circuit board.
Where are PCBs used?
They’re used everywhere!
Did you know?
We call these legs "component leads".
This is Georg Simon Ohm:
You will see the number of volts written on almost every battery as it’s one of the most important pieces of information about the battery.
For example, a mobile phone has a battery of 3.7 volts, and a car has a battery of 12 volts.
Useful tip:
This particular battery size and model is called a CR2032 coin cell battery.
This particular motor type has a special name - an ERM motor.
An ERM motor has an off-center load, and when it rotates, the centripetal force (a force that makes a body follow a curved path) causes the motor to move.
This motor has two wires coming out of it.
The colors of the wires (red and blue) represent the polarity of the wires: blue is negative (-), and red is positive (+).
These wires are used for connecting the motor to the power source (battery) and powering the motor.
This is an electronic symbol of a motor:
Historical fun fact:
What does it do?
Did you know?
2. Resistors
Resistance
3. 3V coin cell battery
Useful tip:
4. Battery holder
This battery holder is a plastic electronic component with two springy metal legs.
It is used for holding the coin cell battery in place and connecting it with the rest
of the electronic circuit.
5. Vibration motor
This component makes MR. BEE vibrate and move around.
6. Switch
BackNext
